I have a 25R75B outboard. I was trying to use it this weekend and could only get the top jug to fire. I swaped plugs and it was still only the top jug.
I was going to pull the flywheel and check the points as I have in the past.
This time, it broke around the steel spider that is cast into it. I then had to take it to a machine shop and they used some type of small cutter wheel to slice into where the key is and spread the hub and it came off. Long story short, the points look good but I am in need of a flywheel and I cant seem to find one. Any ideas of where to look? Google has only found places that show it as obsolete and unavailable.
Thanks in advance
Will
Thanks in advance
Will
