Which is the worst case for a cylinder in these two scenarios?
PaulO
Water getting into cylinder/s causing rust
or
A heat seized engine?
thompy
Re: Which is the worst case for a cylinder in these two scenarios?
i would have to say heat seized can do more damage to the cylinders but water will take out all the bearings as well
pnwboat
I would tend to agree with tompy. Heat seized engine has a much greater chance of causing damage to multiple engine components.
PaulO
Thanks for your opinions.
Paul
Frank Acampora
Is it worse to be killed from a knife to the heart or from a bullet to the heart?
Each scenario can damage the engine to the point where it needs rebuilding, OR you might get lucky in either scenario and only need minimal repairs. So which is worse? It depends!
