Where is Thermostat
JimbC
Re: Where is Thermostat
So what are you saying ? That the there might be a thermostat under the exhaust baffle.:eek:
hl
Go to MERCURY OUTBOARD REPAIR VIDEO and this will show you the steps you need to take.
JimbC
UMMMM! You think you could be more specific with (Go to MERCURY OUTBOARD REPAIR VIDEO)
hl
Go to Yahoo.com. Type in Merucry outboard repair video. There you will see selections of repairs.
JimbC
Well I see nothing in the way of videos for this maybe you could provide the link.
emckelvy
OK, this has really gone off the rails, let's be very clear, NO Inline Six released by Mercury for production use has EVER has a thermostat. To tear the motor apart looking for one would be counterproductive.
Best maint on an I-6 is to do routing decarbonization treatments, ensure the cooling system is working properly by servicing the water pump/impeller periodically, and making sure the timing/synchronization is correct.
Here's some info on decarbonizing and Link 'n Synch procedures that should help:
http://forums.iboats.com/showthread.php?t=158076
http://forums.iboats.com/showthread.php?t=168855
HTH...........ed
latin monkey
I have a 3 cylinder 60 hp merc and the thermostat is located under exhaust cover. i don't have an inline 6, i was suggesting he look there its not hard to do
JimbC
emckelvy Thank you very much for finally clearing this up. Ok so I don't have a thermostat. Glad that is over.:D
ClassyGlassy
I still don't understand why they would put a thermostat in a motor 1/2 the size but NOT in an inline 6 1150! Makes no sense........
