Ran the engine today in the river.
It is surprising the amount of water it was spitting out compared to the muffs. I am happy about that. It ran cool too...approx 80? F. Someone correct me if this sounds too cool?
ISSUES:
1. The tachometer runs upto 2500 RPM but no further. GPS says 67Kmh with a 19P x 13? prop 5.2metre fibreglass runabout.
2. Because I am running at 25:1 oil mix and the smoke runs up past exhaust rubber into cowling, when the cowl is in place it soon cuts out because the engine is ingesting carbon monoxide.
3. I bought a Rectifier/Regulator as per the sticky. It is only showing 11.5 volts on the volt meter that runs from the fwd controls ignition harness. It did increase from a lower figure so something is going on. A navman connected direct to battery shows 12.7 volts at cruise. I put a ammeter in but it doesn't seem to move. I connected it to the rec/reg pos and c/breaker to the + of gauge and the - to the battery side of the starter solenoid. No movement when cranking.
ISSUES:
