Hi guys, I am new to the forum, but need help. I recently bought a new boat with an Evinrude outboard. I have had a compression test done 90-95 on all 6 heads, water pump changed, new lower unit lube, new sparkplugs.
The problem only happens on the water, after I shift into gear the motor dies when I try to accelarate past 1000 RPM. Neutral and reverse are fine. Whats weird is if I sit there and keep going from neutral to forward sometimes it will work and run up to full RPM's....???? Any ideas???
Thanks,
-Eric
Thanks,
-Eric
