Our 1996 50 HP Johnson carbuerated outboard originally had a VRO type pump. The oil pump was disconnected when I got it. Been using mixed fuel ever since.
Idles OK, runs fine in neutral at high speed but when actually in gear and under way, engine will bog down at anything more than 3/4 throttle. If I squeeze the primer bulb engine will run fine again, temporarily... Diagnosed by multiple mechanics who all said the same thing... Replace the pump. We did. Problem remains. Here's what we've done so far..
New fuel. No improvement
Fuel additives to clean out gunk in carb. No improvement
New tank hoses and primer bulb. No improvement
New Fuel filter. No improvement
Check for vac leaks None found
Tried known good fuel tank. No improvement
New pump, filter and lines. Slight improvement
Again, sqeezing primer bulb helps. With the cover off we can use the filter as a sight glass and see the fuel dwindling when the engine is under load. It's obviously a fuel starvation problem. What's not so obvious is why..
I am new to pulse driven fuel pumps and can't seem to find the exact OEM service manual for this engine. There are three lines leading from the fuel manifold. Two go to each of the 2 carbs.
The third line goes to a round device (some sort of fuel pressure sensor maybe??) with a couple of wires and a knob on top of a red indicator dial. (The knob resembles a tire stem cap)
Does this device control the "pulse" to the fuel pump? Is it adjustable? Where can I get an OEM JOhnson manual specific to this engine? Preferably something other than Seloc or Clymer.
