Re: On the lake - sputtering - anything to try?
When you say "sputtering at high speed" is it cutting on and off or surging?
Steve
It would hesitate and bog down as if it were suddenly starved of fuel and/or spark. Then it would pick up for a bit and then do it again. The longer we went (holding at around 4700 rpm), the more frequently it'd sputter and bog. While I still noticed it, it was much less apparent under 3000 rpm.
I've been through just about everything electrical (distributor, cap, rotor, points, condenser, plugs, wires & coil - all changed between the winter & today). On the fuel front, I've replaced the fuel line, cleaned the pickup, replaced main fuel filter (twice just to be sure), cleaned the strainer at the carb & rebuilt the carb.
I've also bought a dwell meter & checked that as well as set the timing (again, all this just recently before today's outting).
Really frustrated and not sure what to attempt next. Should I rebuild/reclean the carb again? Should I be concerned about my fuel pump (& if so, how do I test)? Am I missing something electrical? I feel like I'm REALLY close to having a decent working boat, but something is elluding me. Certainly ruined my mood for the day.
