I just recently purchased a 97 Celebrity 180 Bowrider and am new to boating. The boat has a 4.3 v6 Mercruiser LX engine. When out on the water it has no power when accelerating. It just sounds like it doesnt have any power. Its not missing while its doing this, it just simply sounds like it doesnt have the power. It VERY slowly accelerates and eventually will plane and seems to run fine after that but its only running 4,000 RPM at full throttle with only about 250lbs of weight inside.Browsing all over the internet I found that this motor should peak between 4,400 and 4,800 RPM's. It has new spark plug wires and I checked the plugs themselves and they look farely new. Also removed and rebuilt the carburetor which after getting inside of it looked as if it didnt need it at all. Everything was clean and working properly.
What else could be the cause of this?
