had idle problems, seem to have gotten them resolved now in gear will not go above 2899 - 3000 rpm. So far, rebuilt all 4 carbs and VRO fuel pump. Checked compression 138 - 142 psi on all 4 cyls. Checked spark all 4 have nice bright blue spark across 7/16" gap. Idle seems really stable at ~800-1000 rpm, even when hot. in neutral motor rev's well, under load (in gear) will not go above 2800- 3000 rpm. boat will not get on plane. removed plugs and looking at motor from rear, right bank looks good, no fouling, left bank both plugs looked fouled, covered in carbon, top cyl is the worst. any suggestions on what to check next?
