I have searched on here and found the same problem but no solution. I am installing a new head unit and speakers on my boat. Before I install them I hooked up the power and memory wires from my head unit to an inline fuse (10amp) direct to the battery. I have the ground wire from the head unit direct to the neg terminal. My head unit display flashes on and off. Its not like its turning off and on, I changed the volume in the second its was on, then the next time (a second later) it was set at the same volume.
Here is the thread that looks like the same problem.
http://forums.iboats.com/showthread.php?t=320197
Any help would be great!!! Thanks!!!
