Outboard dies after starting.
Sparkz
Hi I'm after a bit of advice please. I've just bought my first boat and am having problems keeping the outboard running. It's a 20hp 2 stroke Mercury. It starts ok and runs for approx 30 seconds, then just dies. I've tried altering the choke and throttle but it doesn't make any difference. I think it's something I'm doing wrong rather than a fault with the engine as it ran ok when I was buying it.
Thanks
Jacket4life
Re: Outboard dies after starting.
A little more info: What is the year model of the motor? What steps are you taking to start?
Wingedwheel
Is the vent on your fuel tank open?
Sparkz
Yes I open the vent. The outboard is somewhere in the region of 25 years old, maybe a little more. I use the squeezy ball on the fuel line before starting it and have tried many different combinations of choke and throttle settings, but it always dies after half a minute or so.
ENSIGN
Sounds like it's running out of gas.Get it started and keep squeezing the primer bulb and see if it stays running.You may have a bad fuel pump or clogged filter.
mbranton
replace the squeeze bulb in the gas line...........the smallest hole can interfere with fuel flow from tank.
