chris71167
Thread starter- Joined
- Jun 3, 2010
- 24
90 nitro tracker with a 90 johnson 150 gt. just bought a week ago changed fuel added seafoam rebuilt all 3 carbs they were nasty and leaking new champion plugs compression is 90psi on all cylinders new fuel filter changed water pump lower unit oil. timed and adjusted linkage according to the manual(was very careful checked and rechecked) runs perfect in the driveway can run up past 3k for a min perfectly. got it idling on the lake perfectly. can increase throttle stops about 1500rpm if i increase throttle past that it stumbles boggs etc and will die. so something is dropping out or not working correctly under load? please help im a ASE certified master tech(automobiles) im either missing something or im just baffled at this sec. this is my first boat.
