anthony10092
- Joined
- May 18, 2009
- 7
My trim gauge bounces all over the place. When I put it away last year it worked fine, but this year it is just all over the place. Also, when I use the trim up switch it doesnt always work. I have to use the trailer switch to raise the motor up. I am going to look at wiring for that issue but am not sure where to look other then right at the switch. The gas gauge worked as well. I put 30 gallons in a 50gallon tank and it is reading just above empty. The lights work on th egauges when I turn the key on so I know they are getting power. Do these gauges go bad over time or is there something in the wiring? I am not sure where to start. Thanks for the help!!!!
