Is there a third terminal on the tach for power? Three terminal tachs need a 12 volt power source from the "I" ignition or run terminal of the ignition switch. Purple wire goes to signal and should be attached to an AC terminal on the rectifier on the engine end. Black is ground and needs to be grounded under the dash. AND, the tach needs to be a 20 pole tach.
Also, how can I check the rectifier?
I want to make sure its the tach before I shell out $50 on a new one![]()
