No Power under Load
mkckm122
I have a Mecruiser 140 85 model in a 17' Runabout. My gears stripped out in the upper drive and I had a mechanic fix it. Before the gears went i was getting 4000 RPM and 35 - 40 mph. Also he replaced the gimbal bearing and the rubber piece for the impeller that suppose to be replace every 2 years. He also said he adjusted the carb a little. Well i got it back and took it to the lake and could not even pull a tuber. I had no power under load, even without the tube i could only turn 2000 rpm and only get 10 mph out of it. I just rebuild the carb last year. Please help.
xltier
Re: No Power under Load
check the gear ratio of the gears in the upper drive by rotating the engine and counting the number of turns it takes to turn the prop 1 turn.most 4 cylinders i have seen run a 1.98-1 ratio.may have got wrong ratio.
