1960 10hp evinrude starts and runs good, but doesn't move
Grantsch
I have 1960 10hp Evinrude motor that I just got today. I took it out on the lake and it started right away. It ran great and got my aluminum boat across the lake. I stopped and when I went to start it up again it started up but the motor wouldn't move. I tried putting it in neutral to forward but it just stayed started and wouldn't move. Do you know what this could be? Thanks.
bktheking
Re: 1960 10hp evinrude starts and runs good, but doesn't move
2 things, pull the prop cone off - remove cottor pin and unscrew it (the cone) and inspect the shear pin, bet it's broken or someone put something else in it's place that broke, or , shift linkage came undone in which case you will need to drop the lower unit to inspect. 3rd thing could be that the PO had the phillips shift screw out and didn't put it back in properly. Check the shear pin first.
AlanR
Id say sheer pin on the prop shaft.
F_R
It is supposed to be 3/16" diameter stainless steel. If somebody put something else in there, it probably just wore itself in two.
Grantsch
How do I get the prop cone off? Do I just pull it off or do I have to unsrew something? Do I just leave the propeller on? Also is the shear pin easy to find?
bktheking
They unscrew, counter clockwise.
Grantsch
Alright, thanks. I did that and the shear pin was broke into three pieces. I was able to find another one and now it works good.
