1970 4 HP Johnson
abloyer
I recently purchased an aluminum john boat. It came with a 4hp Johnson model 4R70E.
Is there a reverse or at least a neutral?
Thanks.
abloyer
F_R
Re: 1970 4 HP Johnson
For neutral when starting the motor, tie it to the dock. For forward, untie it. For reverse, steer it 180 degrees so it points to the rear.
raczekp1
hi.
as i looked at diagram of your gearcase i'm sure there is forward and neutral.
i think reverse is when you turn over engin in the mounting bracket.
abloyer
Gotcha, was hoping that the shifter handle broke off.
Thanks
