90 Sport Jet Carb Issues
kend301
Re: 90 Sport Jet Carb Issues
After market stator , the reading confirms it . The 9887k1 is a CDI stator I will check and see if you should be running the adapter with that stator .
philly5eagle
Ok, thanks alot.
I'm still doing the wd40. I'm going to check compression again tonight I think. If it is still off on the one cylinder then I'm going to swap everything to the other one.
I know it's not the red stator, but will i be ok with that one for a while or should I already start looking for a red one?:) It looks fairly new from what I can see but I can't be sure.
