bhammontree
Thread starter- Joined
- Jun 10, 2010
- 2
Hello
I have a 1986 Galaxy cuddy cabin 19'9" with a 175 HP mercruiser inline 4. I think the motor is also called the mercruiser 470. I have a leak on one of the hydraulic lines going from the tilt trim pump to the transon. One line has a braided cover and one is smooth - the braided one is the one leaking.
My problem is I can not access the end of the hose where it passes through the transom to remove and replace the hose. Is there a trick to getting to that connection to remove the hose without pulling the motor? If not would it be possible to somehow splice new hose on to the old hose so I can cut out the leaking section? The leak is close to the pump so I have plenty of good hose to work with. If anyone has ran into this problem please let me know how you fixed it.
Thanks
Thanks
