lonemust
- Joined
- Apr 2, 2009
- 205
Hey ya'! If I were to put the outdrive (Also a 140) in a plastic barrel with 16" slit cut in the side for the drive with water. Could I remove the inlet hose at the termastat housing to see if it is pumping water. If not how can I tell if the raw pump is working without putting it on the lake. I would like to test it at home so if it needs replaced I can do it at home. 15+ miles to the nearest body of water. My boat is a '70 starcraft with a merc 140 and a 140 outdrive
