exodave
Thread starter- Joined
- Jun 8, 2010
- 107
Model 25930, 35hp
Just starting on restoring this puppy, picked it up along with a 16' Sportcraft SkiKing and trailer, all for $200, been sitting in a yard for I'm afraid to know how many years. The service manual, and full cadre of tune-up parts (carb, coils, ignition) is on the way. I just installed a new starter and solenoid, and have got her running roughly on the earmuffs with a spray of starter fluid, at a rather high RPM, but even though the shift lever is in Neutral, the prop turns, then every few seconds the engine jolts and the prop flies, and it stalls out or tries to.
Just looking for some forum insight before I dive into the manual when it arrives. My thoughts after a little research is that the shift lever is mal-adjusted. Before getting it running, I did turn the flywheel by hand, and it did turn in reverse while the lever was in reverse, and forward when the lever was in forward.
This is my first outboard motor, after experience restoring a motorcycle '78 Kaw KZ400, so I'm good with small engines, but all this on the lower half is new to me. So I'm open and appreciative of your wisdom!
http://www.flickr.com/photos/exodave/4692204494/in/set-72157624130590169/
