Quick report on Minn Kota 45lb V2
sierra 18
I recently bought a Minn Kota V2 PowerDrive trolling motor. After mounting it on the bow and wiring in a Minn Kota plug and receptacle, I put it to work on a few different lakes and rivers.
Observations:
1. I have a 14' aluminum Lowe fishing boat, with side console and a 35 HP Johnson on the transom. The salesman said the 45 lb would be ample, the MK website steered me to the 55lb. Since using the motor, the 45 lb is very ample, pulling the boat with 2 big guys and equipment at 2 knots in light winds.
2. Consider buying the optional wireless remote; the foot pedal is fine, but very sensitive. As a result, you can oversteer and I found I was often correcting back and forth to get the direction I wanted. The wireless remote put the control on a keyfob that I wear on a lanyard, so its conveniently at waist level for quick access. Since I have much more dexterity in my hands than my feet, I steer much better with the hand control over the foot control.
3. Battery life with this unit is amazing. I was on the lake yesterday, light winds, and except for crossing the lake a few times with the outboard, I used the electric motor from 10:00-14:30, to move along the shoreline trolling, to move into shore to work the shoals, making frequent course corrections to avoid rocks, to manouver around islands, to work weedbeds. I used the helpful battery guage on the unit at the day's end, and found I still had 3/4 battery left (12 volt battery, dedicated to the trolling motor; my other batter is for engine cranking, fish finder, horn, etc).
4. Some have said that the deployment and retrieval of this unit is poor, but I have no problems with this. You just have to be foreceful in pushing the launch lever to thrust the unit from its mooring and out for deployment. Same with retrieval, you just have to be forceful in pulling it back into the holding mechanism. I launch and deploy frequently when I put the anchor in to avoid the anchor line wrapping around the trolling motor shaft.
So far, its a powerful and handly device. Time will tell on durability. I already inadvertantly hit rocks with the prop, and the prop only has a few minor marks, the shear pin never broke. And, a replacement MKP2 prop is only $14.00.
It has enough power to get you off a lake if your outboard fails, and it sips electricity so you can use the device all day. Too bad the cordless remote is so pricey, my main gripe.
Best,
Chris
RicMic
Re: Quick report on Minn Kota 45lb V2
I have two of that same motor, except both are the 55#. I agree with all your comments. The foot control does get a bit easier to control as the experience level goes up. The first one I bought was for the front of a 1442 Alumacraft jonboat. I had previously bought a 45# tiller Minnkota for the stern, even though several experienced people told me to buy the 55#, they were right. The 45# is more than plenty 95% of the time, but the 55# dosn't cost much more and since its often not working as hard it can use less current to do the same job. Light wind and no current is one thing, strong gusty winds are totally another and sometimes thats the best time to fish! I don't have any problem getting the motor back on board, but over time it does get a bit "sticky" trying to get it to release. A good spritz with one of the vinyl/rubber protectant sprays, slicks it right up and makes it nice and shiney!
sierra 18
You're absolutely right to mention the vinyl spray on the shaft, as it does get bound up and even the manual mentions using a lubricant regularly on the shaft to maintain ease of movement. I could have gone with the 55lb thrust, but it was 20%-25% more expensive, and the shaft is also a fair bit longer and I can barely get the boat cover on the boat with the shorter shaft of the 45lb model as it is. That said, I do agree with your suggestion to get the next step up of power if cost and deck space are not an issue, tho' the 45 works just great for me so far.
RicMic
Spray the protectant on the "docking" area where the lower unit sits also, makes a huge difference. The shaft on both of the motors are really to long, one doesn't cause a problem cause it comes back inside the boat, the other hangs a foot outside, so I plan to shorten it up when I have the time.
