The motor is a 1987, Mercruiser, i/o, 165hp (3.7L 224ci) Let me know if you need the SN#
I have 1 collapsed lifter that needs to be replaced. I have 2 questions about replacing it/them.
Do i have to take the head off in order to replace the lifter or can i do it through the push rod cover?
Secondly, what can i get away with replacing from the following?
1- Just the bad lifter
2- The lifter, push rod, and rocker assembly on the bad lifter
3- all 8 lifters, push rods, and rocker assemblies?
Thank you in advance!
edit -- can i also get a step by step or removing and replacing a lifter?
