duped
Thread starter- Joined
- Aug 26, 2009
- 307
Hi I have a 1986 sea ray 210 cuddy cabin, 21ft, 8 ft beam, est weight with fuel, gear and passengers 4200lbs. Has Merc 305 v8 ( 230 HP ), alpha one drive ( stamped 1:50 ratio ). No hydrofoil, but I have a happy troller mounted, also Bennett trim tabs.
Right now its running a 14.5 X 17 aluminum merc prop. Just rebuilt by the marina in town. The previous one I tried was the same size, but had cavitation burns on it.
WOT RPM varies between 4400 and 4600 RPM which I'm told is correct for this engine. Top speed on my GPS plotter is 36.9 MPH. This was with no chop on lake michigan, going with the current.
Anyways, ive noticed the boat seems a little slow to plane, and I'm not all that impressed by the top speed either, and was looking for suggestions. The boat is very well maintained, not water logged, runs great. Seems like no matter where I put the trim, or trim tabs it makes little difference.
I have a 19 pitch prop on my other boat, and was wondering if this would help or hurt my top speed and to plane times. And then there's Sea Ray's prop chart that recommends a 15 pitch prop for this particular boat and motor, which seems small.
Anyways, what direction should I go for best results... 15, 19, or be happy with where im at??
