2nd bilge pump?
rock10
i just aquired a brand new attwood sahara pump from a friend any there any reason that i cannot have 2 bilge pumps connected for double protection thanks omc cbra cobia i/o
Rocky_Road
Re: 2nd bilge pump?
If this were mine, I wouldn't have it on the same circuit as my original.
But...I would wire it (fused, of course) directly to my battery with a float switch. It would cycle without any input from me, and only when it sensed water intrusion.
Happy boating!
rock10
Re: 2nd bilge pump?
sounds like a plan, thanks
Re: 2nd bilge pump?
That second pump needs it's own hose and through-hull fitting.
commander315
Re: 2nd bilge pump?
yup, itll be fine...id say to wire it to the battery..use a float switch too
Lrider
Re: 2nd bilge pump?
Mine came with 2, the auxiliary has twice the power then the primary
rock10
Re: 2nd bilge pump?
thanks guys the sahara is auto,and will install second hose and thru hull straight to battery with inline fuse what size fuse will 2amp be ok?
Rocky_Road
Re: 2nd bilge pump?
Probably closer to 5 amp...just read the spec sheet on your new pump.
Happy boating!
