Re: Tell Tale
My OMC mechanic removes the thermostat from all 18-25HP OMC motors of the 50s-70s era, he said one less thing to break.
So i'm going to run this by him, and see if he thinks this is a good/bad plan. I'm going to get the spare cover, add the elbow per the forum guru, add another to the left side of the housing and connect them with a hose.
I'll post pictures if this works out.
Here's the size recommended by the guru in another forum:
You just need two parts. A 1/8 brass pipe threaded nipple to fit a small hose, and a couple feet of speedometer hose. There should be a 1/8 pipe plug on top of the block near the thermostat or on the water jacket cover on the head. Barring that, you can make your own hole on top of the block on the flat area near the thermostat on the top of the head.
