wil7483
Thread starter- Joined
- Jan 19, 2007
- 377
I have been in the process of replacing my gimbal bearing, oil seal, shift cable, and u-joints due to the previous bearing becoming frozen to the yoke and causing me major headaches. I have finally gotten everything replaced and back together and today I decided to remove the prop to grease the splines and low and behold it is stuck on the shaft. I have tried to spray WD-40 on it but I don't even think it is finding it's way into the that space to offer any assistance. I then wrapped a chain around the blades of the prop and attached it to a bearing puller and tightened down on it but it actually broke one of the pieces of metal that the chain was connected to on the puller. Needless to say the prop didn't budge. I then made all of my adjustments to the shift cables per the manual and ran the engine with the drive engaged in forward and reverse for several minutes hoping to jar it a loose but that made no difference either. So any other suggestions?
