Magic eraser is the best cleaning product on the planet
nitrosteve
I'm beginning to think there really is magic in it. You know that nasty yellowish stain the back of your boat has if its like mine. This thing just takes it off with very little elbow grease. They are the real deal. Here is the before no after yet but imagine its all white
PS94
Re: Magic eraser is the best cleaning product on the planet
It's basically a 2500 grit sandpaper, in a sponge, and you're wetsanding...
I never thought of it when I was polishing mine last friday.....Took forever to get the scum off!
bcons
Agreed it works great, this spring I had the pressure washer & a bucket of soap with rag, my wife came out to help with a magic eraser & got more cleaned faster with just that sponge......
180Fisherman
Sno-bol toilet bowl cleaner will make those stains dissapear with absolutely NO elbow grease. Spray it on and watch them dissapear almost instantly. Just make sure you rinse it off good and don't get any on your outdrive. That stuff is powerful. Some people will say dont use it cause it an acid but I've used it for years with no ill effects.
Reel Kahuna
Be sure to apply wax over the area you used with that magic eraser.
dkorzun21
Yeah the Magic Eraser works wonders. Ive also heard on here that it removes oxidation from colored parts of the fiberglass as well.
I usally use vasoline on my boat where the red runs down the side of the boat because its very dull. This weekend im gunna try the magic eraser on it to try and remove the oxidation and then the 3m restorer/wax with a buffer.
Ill keep you updated on how it turns out
nitrosteve
you left out the magic part :)
