Stiff Steering
ddrieck
The steering on my current project boat is stiff and hard to turn back and forth. I have disconnected it from the outboard and the outboard moves freely so I know it in the steering cable or rack.
My last boat had the drum type steering and I remove the inner cable, cleaned it with a wire brush, relubed, and reinstalled and that fixed the problem.
My question is:
Is the rack type steering much the same in that it has an inner cable that can be removed and cleaned? I have not torn into the rack as of yet and need to also know if it comes apart much the same as a drum tyep?
Re: Stiff Steering
My question is:
Ayuh,.... A New helm,+ cable is reasonably Inexpensive....
They are Not known as Servicable parts,+ are designed to be Replaced when in the condition of your's...
ddrieck
Re: Stiff Steering
Ahhhh.....but I am cheap A#^ and need to know if it come apart like the drum type..
Re: Stiff Steering
Ayuh,... Some are riveted,+ some have screws,... Guess you'll haveta Look....
ddrieck
Re: Stiff Steering
Thanks Bond-o....as always you are direct and to the point :D ...I'll crawl under there later today and have a look see
