eavega
Thread starter- Joined
- Apr 29, 2008
- 1,377
I have finally put my restoration project on the water, and had a qualified success, but I had a few questions, specifically prop related.
The Motor - 1972 Evinrude 50 HP model 90273C.
The Prop - Assume it was the original that came with the motor. Its a 13 1/4" 17 Pitch aluminum prop (that's what is stamped on the propeller).
The boat - 1975 Yarcraft Yankee 15' trihull bowrider. Per the research I have been able to do, it weighs 800 Lbs dry. Now this may be inaccurate, because I suspect this boat had a new deck and transom put on it in the last 35 years, which may have changed the weight. The hull is rated for 70 HP max, so I understand I am starting a little underpowered to begin with.
A typical load for this boat would be about 750 Lbs (3 fishermen, cooler, trolling motor, extra battery, fishing gear).
I am assuming the tach is accurate, but it is not original to the boat, and I don't have any experience with it. It is correctly connected to the pulse wire coming out of the controls. Verifying the RPMs would be awesome, but I am not sure how, short of buying another tach and seeing if I am getting the same readings.
The issue - Its giving me 4400 RPM at WOT. The speed was fine at about 20 MPH (I wouldn't mind more, but I'm okay with that speed), and it does plane fairly quickly (didn't jump out of the water, but it got to where it needed to be in short order), but I don't want to be lugging the motor or stressing it by not allowing it to run at its recommended 5500-6500 RPMs.
Is the proper course of action to throw on a 15p propeller to raise the RPMs? What is the implication in terms of speed? Or, am I just better off leaving the 17p prop on there and running the motor at a lower speed? Other considerations?
Thanks in advance for your help.
Rgds
Eric
Rgds
Eric
