travelon1979
Thread starter- Joined
- Jun 14, 2010
- 15
Been reading alot of posts on here and various other websites. Seems though this is the best site for intelligent user responses.
My set up:
2008 Stingray 195LX
4.3 Volvo MPI SX Drive 1.60 outdrive ratio
dry weight 2600 lbs / average "in use weight" 3100 lbs with full tank of gas
Z-Plane hull
Current stats:
21P Volvo Aluminum prop 3-blade
WOT RPM is 4750
WOT MPH (GPS) 54
Looking to move to a 4-Blade prop and narrowed it down to these.
1. Stiletto Bay Pro II 4Blade 20P
2. Solas HR Titan 4 20P
3. Apollo 20P
First off, am I going to get lucky and get a response from someone with my exact set up. Trailerboats did an article a few years back with my exact set up, but they did a good job of doing alot of advertising rather than reporting based on all the data they with held.
I am really leaning towards the Bay Pro II but concerned that this particular prop will reduce my WOT too much. Many have said it performs like a prop 1 or 2 sizes bigger. Would it be safer for me to go with the Solas or the Apollo.
Any advice would be appreciated. I should also point out that the way the Stingray Hull is designed the outdrive is higher than on most sterndrives. The boat is also lighter and really sits on top of the water above 35 MPH. At wot their is only a small portion of the boat actually touching the water. Its more like a bass boat in that respect. This may effect some of your opinions on which of these props would be best. As you know this boat will break the 60 MPH mark with the prop ss 3 blade prop. I am more concerned with cruising speed as long as I can keep my top speed around 54.
My set up:
2008 Stingray 195LX
Z-Plane hull
Current stats:
WOT RPM is 4750
WOT MPH (GPS) 54
3. Apollo 20P
