'85 mercruiser 3.0 1500 rpm in drive
roktman
haveing troubles with motor. just swapped a '71 straight 6 mercruiser with a '85 mercruiser 3.0. same mercruiser outdrive. getts full range of rpm's in neutral and reverse but can only get 1500 out of drive...really stumped on this one. needs a tune up but dumping gas fine and firing ok. thinking it has to do something with the drive assembly. any suggestions???
thank you
crdpoker
Re: '85 mercruiser 3.0 1500 rpm in drive
Certainly much more knowledgeable people on here than me, but if I was gonna guess, I would say it's the drive ratio. Guessing your old inline 6 was a 1.65, all of the 3.0's run a 1.98. Even if you change your prop pitch, I don't think it's going to be able to compensate for the difference.
If it's not stamped on the drive, pop the top cap and count the teeth.
-Chris
Don S
1. Boat is too big for a 3.0L engine
2. Wrong gear ratio
3. Wrong prop
4. Less HP
5. WAY less torque
I wonder what could possibly cause your low rpm. :rolleyes: :rolleyes:
wire2
.... gets full range of rpm's in neutral and reverse but can only get 1500 out of drive...
You can run at 4600 rpm in reverse???
