1973 mercury 115 trigger problem
carpenter636
how can i check if my trigger switch is woking not getting spark to plugs the coil is good
carpenter636
Re: 1973 mercury 115 trigger problem
how can i check my trigger switch no spark to plugs but coil sparks .thanks bob
If the coil sparks 6 times per revolution. the trigger is likely good. Clean the distributor cap, inspect the carbon electrode and the plug wires. Do not try to remove the rotor, as they do not come off.
bigred69
Go to Master Tech Marine . com click on the tech assistance tab and then the PDF troubleshooting guide tab. That should get you in the ballpark.
