Menace2Authority
Thread starter- Joined
- Jun 11, 2010
- 38
Hello, been browsing the forums for a while now and I could really use some advice.
I've just purchased a 1979 18 1/2' Doral with a 165 hp in-line 6 Mercruiser engine. Never before have I owned/maintained an in-board motor.
So if you could humour my ignorance it would be appreciated.
A.) I know the impeller hasn't been changed in minimum 3 years so I understand that it MUST be changed before I really run the boat.
Can I do it myself? If so, any links to the process? I am mechanically inclined and do all my own small engine work/re-builds and some of my Truck repair. Are any specialty tools needed? A full step instruction process would be great if there's a link to one.
B.) I was told that the bottom ends have to be filled from the bottom plug up. If this is true I'm guessing the previous owner did not have the pump to do so. If I'm changing the water pump I'm guessing the oil will be drained out of the outdrive anyway, but is it real terrible to fill it from the top? Or absolutely necessary to fill from the bottom?
C.) What would proper running temperature be for this motor with water surface temp averaging 70-80 degrees F.? I'd like to be able to keep a close eye on my engine temp and I'm not sure what normal operating temp should be.
D.) Anything I should be looking for with this motor? Were they problematic in any particular area?
E.) How do I find out which "outdrive" model I have?
F.) Regular or High Octane fuel?
G.) The motor has 825 hrs on it. Is this considered low or high hours for a Mercruiser?
Here's a pic of the motor if it helps at all.
Thanks a bunch! This site is GREAT but I have a hell of time successfully searching for anything on these forum types.
Rob
Rob
