FedUpWithBoatEngines
Thread starter- Joined
- Jun 3, 2010
- 35
Need some help here if possible.
1) My engine over revs.
2) Not sure of prop make. Its stainless though.
3) Best I can measure diameter is 12", I believe its 19 pitch. 3 blade. Numbers on prop are 819K, and a bit further away it has 7732 stamped on it.
4) WOT RPM will exceed reccomended 5250, not sure about speed.
5) Mercury OB, 1990 115 L4
6) Tracker Marine Flats, 1989, 18', fiberglass construction, weight unknown.
Boat seems a bit heavy on the stern while running and I would like to pick it up out of the water a little if possible as well as correct the over rev issue.
