Rscardina
- Joined
- May 3, 2010
- 513
Hey guys,
Scratching my head here... I am having an issue with my outboard that to me sounds like a feul issue but needed to ask the experts before I dig deep into this..
I changes spark plugs yesterday, all 4, have fresh gas, new feul seperator, primer is good..I have the choked key ignition and vro on this..
I went out this morning and started the engine becasue i am planning on heading out tomorrw for some striper fishing.. I pushed in the key to choke and cranked..after two attempts maybe three she fired up and ran..ihave a good tell tale and she sounds like she hitting on all cyclinders.
after i back off the advance on throttle to put to her in idle she runs for a bit, still sounding good..and then cuts out almost as if she had no feul.
I then try to start again after checking primer bulb, throttle position etc..she cranks but doesnt catch on first attempt.. after another two or three tries she goes.. this time i advanced the throttle more to keep her reving at about 1200-1300 rpms.. after a a few minutes of sounding strong she cuts out again!!
I also notice that the vro oil is coming out somewhere under the carb cover..I have not pulled the cover plate off yet..I assume this is not normal?? or isi it? Never had a VRo before..
In one of the picture there is red lever on the choke solenoid..is that in the correct position?
My plan is to verify good spark, and feul..and then move to compression or in some order.. having never rebult this type of carb before i'm a bit nervous..any suggestion on that as well?
Can anyone think of any thing or experienced something similar that I should be checking first?
