Hi,
STILL trying to get my '81 6hp Sea-Horse to start. Just run compression test and got the following results - top 90 psi, btm 73 psi. After I put some engine oil in each cylinder I got top 105, btm 125 ! Can anyone help me interpret these results ?. I did the tests with both spark plugs removed and I also had the carburettor off at the time. Stumped as to why it wont start! Sparks are good (over 1/4" to block), fuel should be good. Only thing I haven't been able to check is timing, but would this stop it firing completely ? Is there a way to check the timing without removing the flywheel ? I've also just tried adding some fuel directly into the cylinders and still nothing - not a pop !.
