muskiehunter507
- Joined
- Jun 19, 2010
- 2
Hey guys, first timer here. I just bought my first boat...an aluminum 1975 mirrorcraft 14ft. I got a great deal on it, however...it does need some work. As of now, the boat is just a shell with a half assed floor the previous owner put in. For now my main concern's are as follows.
1. Replacing foam
2. Replacing wood floor
Of course, money is a big factor in the rebuilding of this boat. So i would appreciate advice that has minimum cost.
My tentative plan as of now:
1. Remove existing floor...along with foam and other debris.
2. Using existing floor as template for new floor.
3. Making a sort of "sandwhich" of foam. Sealed plywyood with a sheet of foam between another sealed sheet of plywood.
*the supposed "logic" behind the 2 sheets of plywood with foam in the middle; too isolate foam from bottom of boat allowing water to run freely to bilge pump in rear of boat.
1. Replacing foam
