Wireing
CarrierSquid
Having a problem with the wireing for the lights and the bilge. It is all hooked up correctly but still wont work. I have a 2 possition switch one each for the lights and one for the bilge with the poss to them and the neg to the battery. Any ideas of why it isnt working?
insearch
Re: Wireing
I think the wiring should look something like this
CarrierSquid
Re: Wireing
ok i think i have it figured out... tested the batery... was good but needed a charge.... my thought is it is the alternator.... i have "juice" to the panel and i have "juice" everywhere else...
180shabah
Re: Wireing
If you have 12v at the panel then your dead light issue is NOT the alternator (could still be bad - multiple problems are not unheard of).
Have you checked for voltage at the devices in question???
CarrierSquid
Re: Wireing
right... yes i have checked it and i have 12v at the panel. the alternator should be the fix to another problem that i have at the moment.
Pokertrampp
Re: Wireing
Did you check for any fuses that are in-line to the device(s)? my bilge has one but it is very well hidden.
CarrierSquid
Re: Wireing
no i havent checked it at the light or the bilge.... will do that tonight...
yes i have ran the wires for each and checked the fuses that i found
