evinrude 25hp help
sljohnson
Hey guys im new to outboard motors and need some help. Ive picked up a used 25hp evinrude and dont know what year it is. The only # i can find on it is serial # 25302 AE0004358. I also know the shaft length is to long, but it looks like it has a removable spacer so it can be shortened. Has anyone ever shortened one and if so what is envolved? Thanks!
tjl76evinrude
Re: evinrude 25hp help
i dont know for sure, but, to remove the spacer your going to have to replace alot of parts. if it is a spacer, the driveshaft, water tube and shift link(or more?) would be lengthened. might not be too easy/cost effective to do without the original parts.
Vic.S
To shorten it you will need to remove the 5" extension, obtain a standard length drive shaft, a standard length lower shift rod, and a standard length exhaust housing to gearcase bolt and shorten the water tube by 5".
The drive shaft is no longer available new.
Woodstock60
you need to check the shift rod length, if it was a factory long shaft then you will have to pull apart the lower unit, which is a big job for a beginner. However if someone made it a longshaft along the way it may have a 5 inch extension on the shifter in which case you just have to replace with a standard size adapter. all you have to do to check is open the small plate on the side of the leg and get a look at the brass connector if it looks like its about an inch long then its factory and bad news if it looks like its longer maybe 5 or 6 inches then your in luck. i may have the parts you need and am willing to just trade through the mail if so. Ronnie
sljohnson
hey quagmire60, i remove the cover over the shift linkage and there was a small rod attached to a brass clamp that must be about 5 inches long. I couldnt see the bottom of the brass clamp. does anyone have the parts to convert to short shaft?
