chris71167
- Joined
- Jun 3, 2010
- 24
I got this boat with unknown history and done a ton of work to it. All work was done according to the factory manual. took it out today. starts right up runs super smooth. in idle and in forward when throttling over 1100rpm feels like it trying but bogs will not die unless throttle is left there.
Ive replaced/checked . compression 95 all cylinders. ran seefoam in gastank/new gas. decarbed motor. new plugs/ coils/fuel filter/power pack/ port side temp sensor/water pump / all new fluids timed, link and sync. carbs rebuilt with new floats and adjusted/ fuel pump screens/ vent screen and pickup screen clear, bulb is fine. the only thing i noticed is during all this testing and repairs was before i put the power pack on it would go to 2500rpm and run fine. so i swapped the old power pack back on and will test tommorow. ANY other ideas?
