Nandy
- Joined
- Apr 10, 2004
- 2,145
For the short version just skip to the questions.
Long story...
I had 3 vehicles with ac problems so when I went to harbor freights and found a 2.5 cfm vacuum and the automotive a/c manifold for $40 dollars less than regular price I knew I had to have it. Here a simply vacuum and oil fill cost $160.00. I had 2 cars that need that and one that I had no idea what was the problem. Today I set up to tackle one car, maybe 2.
The altima ac was not working at all. When I went to work in it today I decided to find the clutch power input so I could hot wire it if I need to. I wanted to do this with a cool vehicle. To my surprise, I saw that the compressor did not have a belt. Easy fix... Got the belt at the local autoparts and fire it up. The cars started to make a bad bearing sound. I fire the ac at full blast check the manifold and added 2 cans of gas and it worked. I looked for the bearing sound and found it to be the bearing for the idler pulley. $50.00 new... no way, went to the local junk yard and after inspecting 2 vehicles I picked the pulley that felt smoot and no shaking. Vehicle one fixed...
The camry is an 89 vehcile with the r12 gas in it. It would cool a bit in the night and nothing during the day. I decided to do the retrofit. I read much about it and there are so many different takes in it that there is no way to figure what is what you have to do. So I decided to follow a website instructions. Not being able to find (I had already checked) a shop that will take the r12 for free I reluctantly let it evacuate in the atmosphere. After all, that is what it happens when you have a leak. I vacuum the system for 30 min and stopped for 10 min to make sure the gauges will not move to indicate a leak. All looking fine I did the last 10 min of recommended vacuum. Turn the car and ac for 3 min. and started to load the freon. It did not take long and the ac was cooling fine. 36 oz after I was done. I found that the gauge does not measure accurate and I guess I have a faulty gauge but I will ask for just in case...
Questions:
Manifold: http://www.harborfreight.com/a-c-manifold-gauge-set-92649.html
Vacuum: http://www.harborfreight.com/25-cfm-vacuum-pump-98076.html
The manifold has multiple scales in both gauges. The most outer scales is the 134a scale. When I place my gauge in the sytems the measurements are around the 10 psi and when I use the gauge that comes with the kit it shows over 25 psi. Am I reading it wrong? Having an electronic background I am used to read needle meter with multiple scales so I think Im reading it right, but maybe someone out there knows something I dont.
When I had the vacuum connected to the manifold the oil in it went from clear to a milk chocolate like color. Is that normal?
On the camry the valve was still leaking once I took the hose off. Both the original r12 valve and the r134a valve. I put the cap as it has an o ring and I am hoping it holds. If the regular cap dont work, what are my options?
Any information and help from those that has done this work will be welcome.
Long story...
Questions:
