Re: Boat weight for trailer
A little bit of nitpick, but I disagree with Silvertip. He says
"Trailer capacity is based on several factors among which are frame strength, axle capacity, spring capacity, and tire size/load range. Trailers often use the same frame but alter springs and tires to achieve different load capacity. So check the GVWR label on the trailer. If that label indicates 4000# with the largest listed tire, then you need a larger trailer. If the weight is listed with less than the largest tire, then all you need to do is change the tires to achieve the higher load capacity. 3700 pounds for boat weight does not generally include a full fuel tank, water tank (if you have one), extra gear, coolers and the other stuff one tends to stuff in the boat."
What was left unsaid was that the spring rate should be checked and the axle capacity too. If you check and the brand of trailer can be found at the next capacity you may be able to confirm those things, if any, that need to be stronger. The frame and rollers may also be different.
I think what Silvertip meant was that if the capacity label shows the trailer can carry greater loads with different tires then you should feel comfortable doing just that.
Just verify what you have so you don't end up with trouble.
