How much prop damage before repair is needed
Revtec
I have a 3 blade aluminum prop with one of the blades bent about 1/4" as seen when moving the prop by hand and viewing how close the blades come to an object held in place. The blade looks normal except for a few dings at the edge.
The boat is new to me so I don't know what the boat felt like before the blade was bent. There does not seem to be excessive vibration now and if I hadn't accidentally noticed the bent blade would not have thought anything was wrong.
The basic question is this: How much damage is acceptable (to prevent motor damage) on a prop before having it reworked?
Another question since I may want to get a spare prop. What would be recommended prop for skiing given a 15' Sportscraft fiberglass boat with '81 70 HP Evinrude?
steelespike
Re: How much prop damage before repair is needed
The prop size should be on the barrel or under the prop nut.To do a prop selection we would need your prop size and your present rpm and speed.A tinytach is about $40 and easy to install.Wouldn't worry about a prop until you try your water sports.
As far as the bend it sounds like a little careful use of a hammer on a block of wood could straighten it.(remove from the motor first)If it still seems to measure off a little a repair may be the safest way.Minor problems aren't likely to cause problems but could over time wear bearings and seals.a much more costly repair than a prop repair.My son just had a fairly bad prop from a 88 50 hp evinrude done for about $35 here in central NY.
Revtec
Thanks for the reply. I have ordered a tach and will get back after I know more on the rpm.
I'll take your advise and try hitting the blade with a hammer a few times. When I pull the prop I will look for numbers on prop.
Revtec
Just got a tach installed.
rpm = 5100 at wot (max rpm range for this 70 hp Evinrude is 4500 - 5500)
speed = 29 mph
Load = 2 people & 12 gal fuel
The prop numbers are something like 7608372V but the 7608 has been X'd out and not completely sure of numbers. I presume the prop has been repaired? If so, can it be repaired again?
The OMC manual says original prop for this motor is 13 1/4" x 17 so I am considering a Solas Amita of that spec. Any comments on this prop?
Thanks for any replies.
Brewman61
Ensign
Sounds like your existing prop is right on per the specs you posted.
From your description I think you prop could be easily rebuilt. I've had my 3 blade AL prop redone at least 3 times. It's surprising how repairable these things can be. This year that prop is my spare, as I swapped in a 4 blade SS prop.
I don't know a lot about the specific prop you're asking about but it sounds like it should work.
