please help..New -old boat engine issues-
surftodd
1988 merc 5.7 v8- purchased boat a month ago-
my issues are
hard to start when engine has been running- I need to put it into full excelleration in order to get it started then pull back quickly
when left idling she will eventually stall out after 3-5 minutes
stalls some times between shifts- usual at most worst time possible- next to a strangers $100k boat
Cruises at 24 mph at 2600 rpm- should be 35 mph at about 3400 rpm
wot 27 mph at 3000 rpm- should be close to 40 mph at about 4500rpm
replaced plugs/wires and cap....
anyone know my next step? I am think the timing.. Thanks in advance for any help
64osby
Re: please help..New -old boat engine issues-
My first thought is it's not running on all cylinders.
Second thought is fuel tank vent not open, causing vacuum.
Third would be fuel filters old and or carb gummed up.
A timing check would also be good but it seems that your engine is starving, not getteing enough fuel, if it is running on all cylinders.
Good luck.
