Is it okay to test motor without Core/Freeze Plugs?
hardiek
Can I start a motor without core plugs to test to see if I have a cracked motor? Will it do any harm? It doesn't look cracked, but I want to double check. If all goes well I will pull the motor and put in brass and reseal.
Thanks.
Kevin
JustJason
Re: Start without Core Plugs
How are you going to test for a cracked block if you can't keep the cooling system pressurized?
Start by checking the oil... if it has water and you are missing core plugs you have a cracked blcok.
hardiek
Re: Is it okay to test motor without Core/Freeze Plugs?
Sorry I am new and learning on the fly.
Thanks for the info. oil is clean, no water. Where can I get temporary expandable plugs to pressurize the system?
Also, where can I find a good post on pulling the motor to replace the core plugs?
Thanks.
Kevin
JustJason
Napa is where you can get the expandables. But they are just temporary for testing purposes.
Don S
Kind of depends on what you have. You never told us what you were working on, other than freeze plugs.
hardiek
1993 OMC Cobra 50. I do not see any visual cracks. Thanks.
