wichitamichael
Thread starter- Joined
- Jun 26, 2010
- 6
I have read several posts on this topic on iboats.com. It would appear that the most common issues are:
1- Fuel pump bladders / gaskets should be replaced
2- Carburetors should be rebuilt
3- Fuel mixture is too lean
4- Idle is set too low
5- Compression is too low
I have done 1 & 2 I am going to do 3 tomorrow and I would like to do 4 tomorrow as well, but how do I tell what my idle speed actually is? The manual says that it should be set at 550 - 600 RPM at idle under load and I don't know how to measure that.
To be clear, my issue is: motor starts / runs fine out of the water but IN the water it dies immediately under load. If I trim the motor up until the prop is barely above water it will idle but not in gear. If the prop is all the way down it only starts if choked and will not stay running for more than a minute at idle and dies within a few seconds of being put into gear. Occasionally, if I rev the manual idle (not sure if that is what it is, small arm on the right side of the gear lever) and put it into gear the motor will lurch forward start to get going and then sputter out again. One time it made it up on plane and really got moving but as soon as I slowed down it died again.
Any help would be appreciated. Can't find a mechanic in Wichita that is willing to look at it.
Michael
Michael
