Re: what should i do before starting a motor that sat for about 5 years
I seem to get the job of reviving motors quite frequently and have developed a procedure.
First we need to find out the condition of the motor to see if it is worth spending money.
The link suggested is basically sound but incomplete. We must assume that there is corrosion in the bores and therefore the rings.We must assume that there is possible corrosion in the crank case. Without stripping the motor down we will give it the best chance.
I use a mix of Marvel mystery oil and 2 Stroke oil, with the motor plug holes facing up, I give each cylinder a good dose. Leave to soak over night. Next turn the motor upright, using a socket and wrench on the flywheel nut, try turning the motor over in a clock wise direction. If it turns don't over do it. If it doesn't soak again.
If the motor turns over by hand, using a trigger type oil can, holding the throttles open, rotate the motor quickly and at the same time shoot a whole load of the oil mix into each carb throat. Leave this to soak.
Now we can go to a compression test, but first we need to rotate the motor with the starter motor. This will blow most or the oil out of the cylinders through the plug holes and exhaust.
Now to checking the condition of wiring but in any event we only need to concern ourselves with the starter and solenoid wiring. This is where the manual comes in.
With the starter working, using a compression tester, do the test for each cylinder, recording the readings. Your motor should produce 110PSI or better for each but all cylinders should within 5% of each other. Some slight variance from this is acceptable.
If one or more cylinders show drastically lower readings we have a problem and the cylinder head of the suspect cylinder will need to be removed to check for damage to the cylinder. Often it is just a leaking head gasket so replace the head gasket, both if more than one.
With this test done to our satisfaction it is worth proceeding with the rest.
Wiring, spark check, carb stripping and cleaning, lower unit inspection and service.
Whatever you do don't try firing the motor up until every thing is done. Severe damage most likely will result.
