Egnition Problems..
rap1668663
I have a Evinrude 1970 2 stroke 60 HP.... when the motor sparks it has good spark,but then I loose spark and while running it shuts off and I have no spark, after moving different wires I get spark back , but Im not sure if its a wire problem or something else..has anyone else had the same problem as me or if you know what I can try I would appreciate it....
Daviet
Re: Egnition Problems..
It sounds like you might have an electrical component heating up and failing until it cools off.
You need to get the OEM manual and use the troubleshooting section to try and find your problem.
