After removing bad gas (water) from the tank and all lines throughout the motor I am still having an issue. Sometimes the motor cuts off completely. It happens at Idle and up on a plane. If I pump the bulb the motor will keep running. At the house on the hose I can watch the water level in the clear Filter drop eventually to the bottom of the actual filter part (making the filter canister about 2/3 full) and then it will stall. I have replaced the 3 Low pressure pumps, and as stated before all lines and tank are clean. I have not replaced the bulb but now I am thinking that maybe its bad. It will pump up full and hard but will not stay hard all the time. It won't suck flat and there is gas in the bulb but you need to pump it. Is the bulb suppose to be firm, could it have a bad anti reverse flow valve or something.
Any help appreciated.
